Keith Spencer
Hi all,
Cutting a long story short, I have a 2009 fiat ducato bessacarr motorhome and on trying a new obd scanner, I found that the can low pin 14 would rise to 12.4volts when the ECU goes to sleep.
I have checked the canbus hi/low signal with oscilloscope and signal looks healthy. Checked the end resistors and I am getting slightly low 48 Ohms resistance, should be 60.
I am suspecting a slightly faulty module/ecu/node that is leaking the voltage back when asleep.
The low resistance could be the addition of a non standard device or module onto the canbus system, possibly the tow bar, by the previous owner.
I would like to find the location of all the canbus modules so I can do a systematic removal test to find the faulty module.
I have already disconnected the abs and air bag, but the voltage remains?
If anyone can point me in the direction to obtain a wiring diagram and or module diagram that would be excellent. Or tell me where they all sit?
Many thanks Keith
Many thanks Keith
