I'm aware that there is currently a similar thread by another member, but I've been in contact and found out that this alarm I'm planning on buying is by another manufacture so am for now asking some direct questions linked to this unit.
I've got a PDF of the instalation instructions. Now I'm almost sure that the indicators on the Stilo are CAN operated?
So in theiory this alarm, if fully Stilo and CAN disposed should be able to operate the indicators via the CAN. What has stumped me though is the fact that according to the fitting instructions its got to 'indicator light' feeds. These on a regular system would be fitted to left and right indictor wiring looms. On these instructions it states that these are not used when the system is installed in the Stilo. So I'd assume this means they're CAN operated using the CAN connections (3 connections in total).
These connections are;
Many thanks.
Jon.
- Can bus line - to WHITE wire pos. 10 of the 32 pins BLACK connector
- Can bus line - to BLUE wire pos. 28 of the 32 pins BLACK connector
- Can Bus - to LIGHT BLUE/WHITE wire pos. 34 of the 36 pins BLUE connector
Many thanks.
Jon.
