Can there be a hole in my exhuast system...?
K
Keval
ey ppl.. sometimes my car dont pull every good.. and sometimes it does.. can there be a hole in my exhuast system? also iv put a sports back box in my car and you cannot hear much of the back box.. can there be a possiblity of a hole in my exhaust system?
There has to be at least one hole. That's where the dreaded emissions come out.
Mark.
Council estate lad.
And proud of it!
A battle of wits with the unarmed is no fun!
Member of the Guild of Experienced Motorists. Lapsed.
if there was a hole you would know about it plain and simple, it will make a horrible farty blowy noise (i know... my manifold is still stuck tight :()
re the car not running right sometimes, it could be a whole host of things, when was it last serviced firstly?
Andy_sx
this is what u do, start the car, let it run a a few minutes, get underneath it, take a tissue, run the tissue around the exhaust, because the tissue is so weak and light, it will move at the just slightest blow. concentrate on all the joins and the manifold. if there is one, some gun gum should sort that right out :) and as for the performance, as andy said, could be anything. try some redex. filled the tank up to the rim and put half a bottle redex in. and give it a little ragging should sort it i recon :)
Follow My Project
rather than put redex in (you may as well be putting fairy liquid in) i suggest you get hold of some Forte Advanced Gas Treatment. Usually available on ebay...
ey guys.. well it was last serivced about 2 months ago... yeaa i will try that and see what happens thanks for all your replys!:D
a service is usually my first port of call...
check you have the correct level of oil though. wouldn't be the first time i've seen a garage overfill one..
Buzz
The champion of the Bravo 1.4
& now ex owner of a Bravo 1.8
J
967
jason
J
F
7K
F1-ANG
F
J
1
1K
Frank
F
P
15
12K
Dark Lurker
