Can someone help?!...
J
Jorge Marques
Fuel Injector Light comes on when its cold weather, and the temp gauge stays down.
It may not be the injector at fault.
According to the repair guide here in the forum its the temperature switch on the injector that may be faulty.
My car is a Bravo12v 1.4 sx 1996
Does anyone know how to repair it?
can anyone post some pics so i can repair it without taking it to Fiat dealer.
Thanks in advance
best regards to all.
JM
Best way take it to fiat and do a diagnostic check.
sven
Thanks Swen, but in this moment i cant afford it.
Re: Thanks
does your speedo work properly?
Buzz (formerly LightWarrior)
The champion of the Bravo 1.4
Re: Thanks
DONT TAKE IT FIAT THEY CHARGED ME £70,GET A MOBILE MECH TO DO IT ONLY COST ME £40
Re: Thanks
Yes mmy speedo works properly
the strage thing is thata the injectors light nly gets on when is extremelly cold like in winter
during summer no problem
thnks for ur help
Did you check your thermostat ?. does the heater blow warm air in cold weather or does it take a long time to warm up ?. If so, could be the thermostat. But if not, get a diagnostic done..
Owen.
hi mate,
it definatley sounds like the thermostat, i had the same problem only in winter and when going down hill when theres not much strain on the engine, it would get really cold and then the injector light would come on, it is the thermostat jammed open, you will need a new one!
my heater still blew out hot air though
thanks for your help, will change the thermostat.
jorge marques
Fixed!!
The temperature sensor in the radiator, was changed , and the light never came on again.
just a quick point about the diagnostics :p sod the £40 mobile or the £70 main dealer charge, get on ebay and buy and OBD2 diagnostic tool! i got mine for just shy of £35 when i got it! best thing i ever bought, got one for the golf too as well as vagcom, there really not that hard to work
Assuming you have one of the 2 Bravo variants that is ODB2 compliant.
Otherwise its useless.
hi my fuel injector light is coming on aswell. it comes on and off, cant really tell a pattern as to when its doing this but, im looking to get it diagnosed this week. more money :(
