I would say so and give better sound too if you amp them up.hi,I have same situation got myself a sub and some 6x9`s. but would it b easier for me to ell on the 6x9 (probably make a profit) and buy some front speakers that fit straight in no hassle.???
Fenton_jd, by wiring your presumably 4ohm speakers in parallel, you are presenting your amplifier output stages with a load of only 2ohms. This will draw heavily on the power supply, resulting in clipping when the current runs out. Typically, clipping produces a high frequency, high amplitude signal that will overheat your high frequency drive units in very little time, and possibly damage your output transistors. Plus, because the impedance is variable with frequency depending on the speaker, electronic damping will be poor, resulting in poor drive unit control.
Wow are you a sound engineer? Your knowledge in this field is impressive
Fancy being the mod for the I.C.E Section? :slayer:
