dumbledore
Established member
- Joined
- Jul 4, 2010
- Messages
- 745
- Points
- 194
Gas(air) + Brakes = ****ed really
get the system bled
Ziggy
There is no air in the system as I bled it and replaced the fluid. From what I read, the brake pad itself when heated during a brake session can generate gases. The gases then get trapped between the pad and the disc causing the brake system to show signs of fading. This is why cross drilled and/or grooved brake discs are recommended. Obviously a good make of pad could also be less prone in generating such gases.
