I've been given a new graphic card, can i run 2 or do i have to disable the on-board one first?
If it has those 3 outputs then use the DVI to run the monitor and the HDMI for the telly.
Be aware if it's a big telly at a high res the card might struggle to smash out two displays.
Well use the VGA instead then?
Some mobo's will allow you to use both, although your better off using a card that has 2 outputs and lets you have the shared RAM back.
DVD player with usb input!!! about 40 quid
if its a new fangled pci slot soapy may send you a spare card to try with.
