Just wondering is another 500 owner can help me (jrkitching and bgunn, I'm looking at you )
Long story short, I took my 500 in for its MOT today and I got failed because apparently there is a cut in one of the tyres which was almost down to the cord. Was told that both front tyres were fairly worn on the inner edge anyway. Picked the car up and pretty worn was a pretty bull5h1t description. I'd say f**ked would be more apt
That's pretty ***ed isn't it? Sadly there's plenty of meat on the centre of the tyre and the same on the outside.
Now as most know I'm pretty anal when it comes to tyres and I know that up until about 3k miles ago all the tyres were wearing very evenly. I took the nearside front wheel off a few weeks ago to grease up the pads and there was no silly wear. Anyway, I needed to pass the MOT so I needed to replace one or both tyres there and then....
Cue driving around Llandudno and Mochdre either looking for Bridgestone or a Michelin or something decent or just a really really cheap nasty tyre to get it through the MOT at which point I could order a pair of decent tyres online and get them fitted at my leisure. No such luck. It was either overpriced crap or just expensive stuff that I simply didn't want. Luckily I've got a set of winter tyres at home so drove home, fitted 4 tyres in record time whilst multitasking (arguing with the wife who said I wouldn't get it done in time) and drove to the dealership for my winter tyres to be checked over.
Receptionist said that the MOT tester had considered failing me because my wheels were rusty...... :bang: Yeah they are rusty but it's just surface rust and I'd love to see him get a screwdriver through it..... Anyway got my MOT certificate.
Anyway, I'm sure anyone who knows anything about suspension will say that it looks like I'm running too much camber. Jason mentioned a while back that if you fit the top mount the wrong way around, then you'll get an extra degree or degree and a half of negative camber on the front wheels.
So basically if you have the little pointy tab facing the wrong way around you'll have too much negative camber and you will end up with tyres like mine. If someone who's not afraid to get ever so slightly dirty and has a 500 that hasn't had its strut top mounts changed could have a look under their car and report back I would be most appreciative. You can just pop your hand underneath and feel the tab at the back.
This is the view of the side of the strut top mount nearest the firewall of the car. You can see the tab
Here's the front end of the strut top mount, note the hole and absence of tab!
So not really sure where to go from here. Need to first make sure my strut top mounts are fitted the right way around. If they're fitted the wrong way around then its happy days and an easy fix, if not then I'm stumped.....
