Technical cambelt help
coupe/ed
hi all,new on ere just wanted to know how i can tell if the cambelt needs changing,the previous owner says its been changed but no reciet,and if any one in northwest can reccommend anywere cheap that would be great!!
cheers eddy
cheers eddy
My best advice to you is, if you are not sure, and no receipt, get it changed ASAP. You could take the camcover off and inspect the belt. If its just recently been done, it will be "as new" condition, not shiney, and the part number on the belt will be clear. Coupe belts have a tendency to snap when not changed, so get it sorted pronto!! Oh one thing, if you have the belt done, have the tensioner and other pulley changed and the water pump. Thats the correct way to do the job.
Andy.:)
Yup and getting it done 'cheap' will still be around £400, dont know anywhere in the north west, wish i did, and i asume you mean north west of England! You could try Fast Fiat at Stockton on Tees over by Middlesbrough just the opposite end of the A66.
Coupe friendly garages here http://www.fccuk.org/forum/ubbthreads.php?ubb=showflat&Number=168875&page=1#Post168875
Post up on www.fccuk.org/forum and you'll get lots of suggestions (y)
It's not worth taking the risk with any belts on the coupe...breaks mean mega bucks worth of damage potentionally!! You need to change all of the belts (aux belts and cambelt), plus tensioners etc as it's often the other bits that go and take out the cambelt doing all the damage
There are 2 on the list i wouldn't use for sure. James Twist and Solo Italia.
Andy.
if your only 60 miles from penriff hows about rayrigg motors in windermere theres a guy who can do it in 3 hours flat even thou the book time is 12.5
and it will be done all properly i have seen him work no sholder bolts and no corner cuting even puts a tap and die set into use cleaning up threads as he goes his name is alan dawson he achived top thechition awards from fiat several years runing and is now ata aproved if you look on the ata website for local aproved technitions
Whats he charge for that?
well he works at a fiat dealer
they seem to charge alot less that other fiat dealers do for it not sure as i have never asked
mabey you could give them a ring and ask
i believe it is around 55 an hour mabey 60 if fings have changed
well,i know with bmw the service history is computerised and you can get a run off of the service history from the dealer.did fiat change the band,and are the records computerised?
its a lot of trouble to go to if it has been changed so maybe do some detective work first!
