Technical  cambelt change
taffy431
i currently have a 2007 grande punto 1.2 active 8v. At a recent service at 21000 miles i was advised that the cambelt is due for replacement, to my mind this sounds unneccesary. What is advised. Thanks.
Might as well get the water pump done at the same time as the cam belt has to come off anyway. This also means having your antifreeze/ coolant drained and renewed with winter just round the corner its not a bad thing
AFAIK it is being done, along with brake overhaul, oil change, fluid check & change & all filters, but will check, thanks for pointing it out :)
i just had my cambelt changed for 230 but they did not change the water pump as it look in fine condition after reading horror stories on here i am worried that it may yet fail. so was thinking of getting the pump changed when i get a service
It's worth changing the cam belt every 4 to 5 years reguardless of mileage. I have had two mates who's cam belt snapped, the result is knacked engine. On a 07 plate, its about the right time to change now plus changing the water pump at the same will also safe you money in the long run.
My grande punto has done 87500 miles and it's never had a cam belt change lol but it's been done on Friday
