R Rizzini7 Guest Mar 4, 2006 #1 Getting my cambelt changed asap (51 reg 100 hlx now on 51k). I know ive got to replace belt, tensioner and air con belt. Is there anything else i should get changed at the same time?
T Trev Guest Mar 4, 2006 #2 The water pump and with the water pump water/ antifreeze at 50/50 mix Trev
OP OP R Rizzini7 Guest Mar 5, 2006 #4 So all i need to change is cambelt, tensioner, air con belt and water pump and water/antifreeze?
T Trev Guest Mar 5, 2006 #5 When I had my HGT done all the belts tensioners etc + water pump 50/50 mix antifreeze
A Anonymous Guest Mar 5, 2006 #6 Water Pump doesn't need doing on a 1.6. Its the HGTs that develop the problems and have them changed. Joske
