General  cam belt changed
i was actually planning to fix a recent diesel leak i found at the fuel pump at the same time, but i didn't really have enough time and i found out that i can remove the fuel pump through the holes in the timing belt sprocket, so i will attack that another next weekend i think. only other little niggle is that there is also a recent oil leak coming from the bit the oil filter screw onto, the same bit with the two pipes heading off to the oil radiator. i have picture somewhere, i'll load them to the computer and add them in an edit.
