but why are you needing to change all 4 disc and pads the same time
YcMing said:but why are you needing to change all 4 disc and pads the same time?
YcMing said:I could do the front brakes for you.
Ming
Mrcento said:the fronts just look like a fairly standard front end brake change job tbh
http://www.fiatforum.com/stilo-guides/238978-swapping-discs-pads.html
YcMing said:if the 2 bolts are off, and the caliper doesn't come off easily or a slight tab with a mallet, then the caliper is at fault
Ming
YcMing said:Agree, i hate those stupid noises just start for no reason!!!
ming
Mrcento said:heard something about caliper dust seals or something on stilos rotting, when they go they cause brake squeak/squeal
don't quote me on that, just remember something vaguely from a few years back
PNL said:Muppet if your having rear caliper problems then no doubt they are on the way out and starting to bind..I doubt very much if fiat would even supply new seals they just want to sell you over priced calipers and the rears calipers are right sods to strip and rebuild if your not savvy to how they go together..as a stilo owner you know there are very strict rules regarging removal and fitting and in particular attention should be payed to slackening off the hand brake before doing anything dont even think of touching them unless you can rewind then with ease..if the calipers are goosed then your better off with replacement for little links and stuff remember this thread.. http://www.clubfiat.net/suspension-braking/2816-sticky-rear-caliper-brake-pad.html and as a bonus you get to meet Mrs PNL on that thread posting on my behalf while I was layed up and couldnt walk..[dont forget to wave ]..:wink:fftopic:
YcMing said:Simple with binding caliper, handbrake off and see if u could pus hthe car without effort.
Go to halfords, they sell poly exhaust mount made by poweflex.
Ming
