Caliper problem
Caliper problem
S
Simon
Almost finished replacing front discs & pads on an 80SX. However, the piston in the o/s caliper will not budge with G-clamp and I can't get the inner pad clips inside the piston.
I did remember to unscrew the master cylinder cap before anyone asks!
Do I risk packing out the caliper with 2 used outside pads and gently pressing brake pedal to get piston to move again, and try again with G-clamp?
Any other suggestions?
use a bit of wd40 on it let it sock in and give it another go try using a pry bar i.e crow bar something alike that should work if not u may need a new caliper
they screw back in mate i think
They don't screw in.
Either its a duff caliper or a failed flexy hose. Either are potentially dangerous and a safety issue.
Only rear disc calipers screw back in... the fronts should just push back in as usual..
Agree - any hint of sticking piston means caliper change required. However, tried again on Saturday when less stressed - used G-clam with the screw part on the bleed valve side of caliper and a slip of wood east/west across the piston (previously did north/south) and the piston shot back in.
Job done, but must remember to check brakes not binding for next few weeks just in case...
W
919
wakka
W
T
1
795
Joseph
J
K
3
424
K
O
3
562
K
V
5
738
Laurie
L
