smartalec247
- Joined
- Jan 24, 2008
- Messages
- 3
- Points
- 1
Hello - I Have A Punto 52 Reg. Had A New Cam Belt Fitted And Ever Since I Have A Bubbling Noise When I First Start Up The Car. Seems To Effect The Temp Cage A Little. Also When I Accelerate (when The Engines Cold) It Whistles Abit Thru The Lower Gears. Most People Think Its The Head Gasket Going But I Have Checked The Radiator Bit And There Is No Bubbling In There. The Bubbling Sounds Like It Is Coming From The Passengers Side Of The Engine. Problem Is If You Lift The Bonnet With The Engine Running You Cant Hear It! You Can Only Hear It When Your In The Car. Any Ideas? Any Tips I Would Really Appreciate. I Dont Want To Go To A Garage And Have New Head Gasket If Thats Not The Problem. Thank You
