brrrr i need warming :(
pghstochaj said:
Yes, solid concrete.
the piping for underfloor heating is usually embedded inside the concrete, about 2" below the surface
you could always get a hammer and chisel and see if you have it installed :D
OK, well I am going home tomorrow for the weekend so will come back prepared!
Gaz, normally, if you have underfloor heating, the floor should feel slightly warmer than the ambient temperature, correct? Neither the concrete of the carpet does?
Also, has anybody got any of that spray on glue to stick my carpet back down? ;)
Paul; i know what u meant i just decided to make fun of you :D and just use blue tack to stick it back down ;)
have you looked all around the edges of your room for vents??
have you got heated walls, im very confused now, you have a warm room but no signs off where the warmth is coming from
the concrete should in theory be slightly warmer but half the time because the floor will be such a vast area you wouldnt be able to feel the warmth
But if I use bluetack what will I hid the holes on the walls and ceiling with?
(I know you knew :D)
Hang on? is your room hot or cold Paul?
if its hot quit moaning if its cold turn the storage heater on?
Paul have you got drunk and hit the walls :D
No vents, walls are all the same temperature, not warm to touch and also feel like solid plaster, my next door neighbour has a bit of plaster off the wall and it just looks normal to me. All I have is a vent which goes outside, from the extractor fan in the ensuite.
Maybe it's floor heating then, I guess I could ask at reception but they already think I am slightly weird, not sure why ;)
Use chewing gum- rank but effective plus the added bonus of a fresh and minty smell to accompany the stuck down carpet.
The holes were me trying to find the heating system ;)
I am not moaning, i just NEED to know "HOW?!" - why does this sort of thing not bother the 120 other people? It keeps me up at night! jk
Chewing gum, ok, add to my shopping list :D
David, I double lock my door for a reason! I saw her tonight, she asked what I was doing, I said washing, she said "good, what have you done today?" "i said work" she said I was a geek and should go get drunk, I said I don't drink much, she looked at me as if I had just had a sex change and then went back to doing whatever she was doing!
Last night the idiots took 12 mattresses out of the store room they have broken into/has been left open and played bouncy castles, result? 12 manky and broken mattresses and me unable to get from my room to the kitchen without climbing equipment. Who got the blame? Me. Why you ask? I am the only one that gets up and goes to lecture, hence the first one the cleaner sees every day, hence the one who gets the moans. Oh I love uni.
/more ranting. sorry
you should have said i dont drink much wanna go **** instead ;)
Nothing wrong with a little cross dressing- some of the worlds most stunningly gorgeous men do a little gender blending now and then- brian molko, marylin manson, twiggy ramirez... :devil:
