The RF manual window winder would not wind the window down. Part of the wire mechanism came up the side of the window.
I pulled the door card off and found the plastic outer cable sheath section between the winder and the top mount was in 3 parts.
I wound the end off, got some plastic garden hose and slid it over the broken original plastic part and pushed it hard on to each end. I then put small screws in each end to secure it on the mounts where the original had broken. Then I put hose clamps over each end of the garden hose over the screws to make sure the screws stayed in place, and that my garden hose was clamped on to the original housing where the original outer cable sheath had broken.
So far so good it works! But for how long. What have others done to fix this part. Used ones are likely to be as bad as they are just as old.
