Re: squeaky bremmbo brakes
Could be because of a need to clean the crud outta the calipers, more likely just one of those things. Three things you can do:
1. Clean the calipers, removing the crud, especially the build-up of brake dust etc from the area the pads move
2. Fit anti-squeal shims, about £20 from a specialist uk Coupe forum starting with "F"
3. Fit standard, Fiat issue brake pads, that have foam backing on the which eliminates the squeal
