Quite simple to do really. Mount the lights as I mentioned in post above. I ran a wire from one of the rear lights all the way along where the brake lines go up into the car through the firewall.
Then a wire from the other 3 lights sliced into the one big one. Taking care not to touch the exhaust with it or trap it in the rear suspension (which I did first)
With all them wired onto the one big one. Inside the car I took centre console out, Wired in a fuse to the positive wire and the switch the the negative wire. Splice onto cigarette lighter power supply and done!
My switch is mounted on the side panel that bolts the centre console down aswell
To avoid the exhaust. The 2nd rear wire I went up where the handbrake cable enters the car and cable tied onto there, the front one I followed the anti-roll bar.
Main wire runs up the passenger side. Took a while to do but well worth it
