L
Luciano D'Agrippino
I noticed a slight hesitation when accelorating, It got worse last night and this this morning it was undrivable so I had to it at home and take my old car instead.
I got home early tonight and decided to investigate the problem, I took off the top cover and saw straight away that the earth wire for the coil packs/ht plugs was not bolted down to the cam cover.
I refitted the bolt and checked none of the spark plugs were loose, bolted the top cover back on and then took it for a good run.
I made sure that I gave it a good hammering(this is not how I would normally drive or advise anyone else to do so)and all was well. I thought I would share this info incase someone else in the future has this problem, by the way I was at Brooklands this Saturday gone, a great turn out of Fiats, Alfas and Lancia(Delta's) I tought.
