Technical Bravo hgt fuel leak
matija1991
Hi, I have bravo hgt 108kw 1996.
Problem is, fuel leaking on the side where fuel hose goes on pipe on engine part. I cut 2cm of rubber hose because it was little corupted, and I hook back again with new metal lock (idk how to say that on english). Fuel leaking again i dont know how is that possible and I dont know what to do, there is no way to leak but still leaks, is there a possibility for leaking from metal part of the engine where metal pipe for intake fuel is screwed in?
franglais
Established member
France, Autun
can you post some photos of the problem?
the metal lock are called jubilee clips or hose clamps.
your written english is very good!
OP
OP
M
matija1991
I will try cut the rubber hose about 20cm, and connect new hose with metal tube between old and new hose, i rly dont want to change fuel line from tank to engine
