oil and bearing
check the engine oil level and next time u get an oil change use synthetic or semi synthetic as is produces less wear on engine. could also be the bearing on various pulleys and tensioners. if car has done less then 70,000 check cambelt tensioner, more than then check when cambelt was change to see if the tensioner was replaced. should have been but bearings is more likley.
Riclemus
