Technical bravo 1.6 slave cylinder....
cheers rigby, well we already bled it....and runs fine for some weird reason, anyway will i need to bleed it again with the new slave ?
Yea you will, as when you first plum it all back up and press the clutch pedal it will be full of air, i had to pump the pedal for quite awhile untill to felt good and a constant flow of fluid was coming out of the nipple.
