Hiya, I've got hold of a full Fiat brava service manual and have looked at the removal of the door card as my window motors need replacing and it says you require a special tool, is this really required?
the special tool i imagine is the 'allen key bit' Just a philips screwdriver for around the door card and then its an allen key for things like door handle and other bits.
Not sure on removing the motor but i guess its just a normal bolt
You dont need to remove the door cards to take the door mirrors off do you?? on the bravo its just the plastic cover and 3 allen key bolts that need to be removed.
