Brava front door card and trim removal!
M
Michael
Hiya, I've got hold of a full Fiat brava service manual and have looked at the removal of the door card as my window motors need replacing and it says you require a special tool, is this really required?
the special tool i imagine is the 'allen key bit' Just a philips screwdriver for around the door card and then its an allen key for things like door handle and other bits.
Not sure on removing the motor but i guess its just a normal bolt
Mike
Door card removal requires screwdriver (phillips), allen keys and IIRC hex drive bits.
Nothing specialist at all..
Guides can be found under repair section of the site - with pictures
Members Site ---------My Site
You dont need to remove the door cards to take the door mirrors off do you?? on the bravo its just the plastic cover and 3 allen key bolts that need to be removed.
window motors,.think he's on about the 'side windows' not 'wing mirrors' ;)
7K
David Slaney
J
910
jason
J
G
2
857
T
713
Dark Lurker
I
2
1K
Dark Lurker
