Hi guys, could do with some advice please. My mate phoned me today saying that his 1.6 S reg Brava had started ok and then after a few seconds it started mis-firing and stopped. I went to have a look but he had run the battery low, with the ignition switched on you could hear a "buzzing" under the rear of the car for a second or two and then the buzzing stopped. I am guessing that was the fuel pump so I assume that is working, I have put the battery on charge overnight but I was wondering what else can have failed. I put a cambelt on it a couple of months ago and the cams are still rotating ok, could it be a cam or crank sensor fault? I think that I will pull a plug lead off and try another plug in the end to see if there is a spark tomorrow but any other ideas are welcomed! Why do cars act up when the weather is bloomin freezing eh!!
Thank's for reading this.
Pete.
Pete.
