Technical  Brava Door 'Bolts'
invader84
The drivers door on my Brava is missing a couple of bolts on the 'returner' mechanism that keeps it open. As such, it flaps in the wind a bit.
Iv provided some pics, just wondered if anyone could identify the type of bolt required as I don't have the faculties to measure up myself.
Many thanks in advance.
ImageUploadedByFIAT Forum1427034613.551834.jpgImageUploadedByFIAT Forum1427034629.248070.jpg
Its an M6x14mm cap head bolt
The washer Is 15mm Diameter and 1mm thick so best I can tell it does not conform to the standard form sizes.
I guess I would get a Form D M6 Washer 0.8mm Thick and 14mm Diameter
http://www.nutsaboutbolts.org/formd.html.
You cant remove the washer from the Fiat Bolt since the thread is formed after the washer is put on.
This is what the check strap looks like. If you need to remove it you remove the door card then the speaker. A lot of different Fiats and alfas have them fitted if you need to go scrap yard hunting but saying that watch out for very similar looking yet different ones :p.
