zippeyrude
- Joined
- Apr 9, 2005
- Messages
- 114
- Points
- 95
The problem is on a 1.9 TD tipo, j reg.
Both stop warning lights came on the dash the other day, i have had a look at the bulbs and they seem fine. I am not sure which fuse the brake lights work from but they all look fine. All the other lights work fine at the rear.
Any ideas where I can look now ?
I have remoned the switch from the pedal and tested it with a multimeter, the two positions make and break a circuit relating to the middle pin. Where would the 12v be coming from in this circuit ?
Please help, this happened when i was taking the car for its MOT - bad luck eh !
