brake flaring tools
brake flaring tools
Edinburgh
You will need to buy some 3/16" copper/nickel brake pipe pipe as the hand helt flarers will not do the sttel pipes plus you cant bend the steel pipes easily without them folding. Why not just get the pipes from Fiat. I replaced every steel pipe on my cinq with new Fiat ones for around £40.
Also I wouldn't bother with the cheape flarers as they are useless. In the end I bought a sykes one because I was fed up with the cheap ones wrecking the pipe! Cost me about £150 though.
I bought a Laser one a bit like the first ebay item, but it came with a tube cutter too, which you will need. You can use them on the Fiat steel pipes if you're careful.
Buy a length of pipe, even if it's just a foot and have a practice go before you do it for real. It's slightly fiddly but can be done, even to existing pipes on the car.
Replace all the pipes? To change the one from the driver's side front wheel to the brake servo would just about need the engine out, it's a complete pig of a job - so naturally this was the one I necked off.
Patched a length in at the end of the pipe which seems to work just fine.
2nd item looks a bit more like it!
they are very expensive bits of kit (well one that will last more than 1 or 2 jobs). if it were me I would get it done at a garage, as its gonna cost you £20 for the tool, which you could then try and sell on, but I wouldn't chance it
