General Bought A GT
General Bought A GT
checked the car over agen this morning no oil leaking onto the floor there is a fair bit on bottom half of engine tho may just need a clean
started her up no smoke on startup revved the engine a little not too much due to being cold whitish smoke from back i suspect water vapour
the pipe the dump valve is fitted to isnt damaged at all no kinks etc
there is a small pipe just above where the dump valve is fitted to and that is blocked off
also regarding the boost guage i want i have found a smplifier power cable that goes through a grommet so i am planning on puttin a t piece in the dump valve think blue pipe and feed it through the grommet then from passenger footwell to driver side n onto the pillar then if n e thing goes wrong i can easily replac ethe pipe fromthe dumpvalve unlike if i cut into the dash pipes
