Technical  Bodywork disassembly
fadalfa
Hello,
Does anybody know how to disassemble
1. front wing: I've already removed all screw but is there still a stud on the rear side (near the small side indicator lamp), how to remove it?
2. plastic profile below the doors (in italy we say "minigonne"=miniskirt): I've removed all screw but it is fixed with some plastic pin, how to safely remove without breaking?
thanks and best regards,
Fabrizio
The fenders are also bolted from the inside in the A pillar. The plastic door sills are plugged in with plastic clips. The screws are only the final attachment. Warm them up a bit and there´s a special tool to lift them .
This interests me as a topic, what's the special tool? Or are you just being funny and meant pliers (so far I've found long nose pliers useful to pinch the back of those plastic fixtures with the clips that expand out on insertion, in hard to reach areas, otherwise just finger pinch them)?
Thanks for your kindly reply!
Mhh.. I have to look under the facia panel?
How to unhook these clips? I've looked under the car but they seems to be unreachable :(
thanks and regards,
Fabrizio
There are oval holes in the side sills.
Plastic clips a pushed in sideways in slits on the inside of the sill.
These clips are plugged into the oval hole of the side sill.
You just pull the plastic sill off gently.
