Blue&me incoming call volume
Nikosdiesel
Hi there,
I don't know if any of you have same issue but when I'm driving and have incomming call, the sound of the ringing is so loud that it scares me so much, that I almost loosing the control of the steering wheel. Does anyone knows if is possible to reduce the incomming call ringing volume?
Suspect your phone volume is set to high as a default
Here is a quote from the audio handbook for a qubo:
EXTERNAL AUDIO function (phone volume adjustment)
This function makes it possible to adjust the phone volume (setting from 1 to 40) by turning the button/knob fig. 1 or by pressing the buttons ̄ / ̇ or to exclude it (OFF setting).
The display shows the function status:
❒ “Extern audio: Off” - function deacti- vated.
❒ “Extern volume: 23” - function activat- ed with volume set to 23.
Your volume might be set to max - 40 ( that would make you jump! )
Hope this helps
Ken
Thanks, I will try It right away.
Something else, is it also an option for the ring tone of blue&me? The ringing sound right now is horrible....(n)
