Nickyboy123
Iam stuck people I have a 2018 ducato minibus the reverse lights stay on until you remove a 7.5amp fuse in the underbonnet fuse box once put back the vehicles perfect reverse lights operate normally for 3 or 4 times then there back on.the reverse switch is fine.being a minibus before it's returned to service it has to function 100%.I have even disconnected the reversing buzzer no change.the vehicle has had water damage.have checked the underbonnet relays etc along with the fuses that are situated inside .all the rear lamp connections are good any ideas?
