Bleeding the cooling system on a Bravo
L
Leon
Hi All,
I am in desperate need for some help.
Please can anyone tell me how to flush or bleed the cooling system on a Fiat Bravo.
Many Thanks
Leon.
To take the watter out - undo the screw on the bottom of the radiator, or take the lover hose to it off.
Then open the screw/s (2 if you have air con) on the top of the radiator under the intake plastic and open one screw on the hose from the trmostat to the in car radiator.
Fill in the watter till it starts to get out on the screw on the radiator, then cose it - all other screws the same procedure.
After that is done, turn on the car and put the in side heating on - rew it every 15/20 sec to 4000 rpm till the car fan starts to cut in.
Then check the cooling level and top it if ther is watter missing.
(dont have the diagrams here, so will post the pic later if you will need them)
Members Site - - - - - - - My Site
Bleeding The Cooling System
Thanks for your reply.
The pictures would be a great help if you could send them to me,
Many Thanks.
Leon
Thanks Tom
I'm hoping that this will sort out my overheating problem.
The temprature is going fairly high and the heaters are blowing hot air intermittently.
Yestarday hot, today cold.
