MARTIN1968
- Joined
- Jul 28, 2021
- Messages
- 4
- Points
- 3
I have recently had a new clutch fitted to my 2006 Doblo 1.9 jtd. Bleeding the clutch as I am sure you are all aware is done by lifting the clip on the slave cylinder and pulling out the pipe slightly, the fluid is released via the small nipple to the top of the cylinder. My issue has been that once done the pipe is pushed back in as far as it will go and the clip is closed securing the pipe in place. I then cover the nipple with the small rubber cover. For some reason there must be a build up of fluid behind this rubber cover which eventually pushes it off and the clutch peddle looses much or all of its resistance and getting the car in to gear is only possible by pumping the clutch pedal a few times. Can anyone tell me what I am doing wrong and why does clutch fluid continue to leak from the nipple when I assume it should be pressure tight.
Any help and advice would be much appreciated.
Martin
Martin
