Technical bigger brakes on a sei.
bead blasted. oo, i dont kno anywhere that does that haha.
and most of the surface orange rusty stuff can be rubbed off. so is beeding still a recomendation?
Light surface rust will be removed within the first few miles.
trick for removing a ridge on the outer diameter. remove the wheel,jack up, start the car and drive and take an angle grinder to it(y)
cool. well ill have a closer look tomorro at the disk condition. after some wire wooling ect :p.
if its all smooth i dont tihnk ill bead it, if i cant get it off ill beed :).
also. do these callipers fit straight on. or did i forget to get something?
was i suposed to get a bracket?
thanks for that, i'll be buying a set of new discs, grooved =)
i know i just have to thank someone... i wonder who :eek:
hehe cheers clock34 ur a brake saver ;)
i just found a cheap new set of front discs, drilled and grooved for only 60.00 GBP made by MTEC. any ideas about the quality of these discs? they seem too good to be true for the price
true i dont plan any nutty driving around tracks but for the price they are at i might aswell benefit from the visual goodness behind my rims =D thanks for the input :)
think ill be taking your advice fingers and get regular alfa 155 discs. Could anyone suggest a good set of brake pads?
