smahaley
Established member
Question- how bad is this? Can I just leave it or should I replace it? NB I have not driven the car yet and previous owners put new tires on it so I can’t refer to potentially odd tire wear ….
If damage not too bad it may be possible to put it in a press with suitable mandrels and square it up assuming a good replacement is unavailable.View attachment 479643So … while I’m still working to remove the frozen panhard bar, I removed the larger trailing arms and the passenger side has a noticeable dent / bend - probably someone put a jack there at some point.
I know the square root of nothing, but it occurred to me that it would be reasonably easy (for a non-hamfisted fool, which counts me out) to fabricate a replacement if the part isn't available. I'd not want to drive it as it is.If damage not too bad it may be possible to put it in a press with suitable mandrels and square it up assuming a good replacement is unavailable.
It does look like a fairly simple design, I suppose it depends on the extent of the damage. It is quite a common issue, you can put signs all over cars about where to jack them up, but some will still just chuck a jack in and start pumping.I know the square root of nothing, but it occurred to me that it would be reasonably easy (for a non-hamfisted fool, which counts me out) to fabricate a replacement if the part isn't available. I'd not want to drive it as it is.
Ideal.Well - it looks like I could procure a new one for $56 + shipping... https://autoricambi.us/rear-long-trailing-arm-1969-78/?setCurrencyId=1
Just be sure to order the correct side - some of those arms were sided left or right - the difference being the orientation of the parking brake cable support bracket....Well - it looks like I could procure a new one for $56 + shipping... https://autoricambi.us/rear-long-trailing-arm-1969-78/?setCurrencyId=1
Thanks again - and I did just receive the new replacement. Guess what? No parking brake support! So I suppose they just manufacture the one and leave it to us to figure out retention of the parking brake cable.Just be sure to order the correct side - some of those arms were sided left or right - the difference being the orientation of the parking brake cable support bracket....
