Hi, I have Barchetta 1998-1999 model, and having problem with airbag light.
I have read through the site, and found out the followings.
1. The first aid is to lubricate the yellow airbag connecters under the seat.
2. Use multiecuscan for detect the problem location.
3. Airbag computer (Change it or lubricate the connection.)
I have done the 1, and there was not changes. Then I found out the my airbag light is not "blinking" when I start the ignition on. This means that Pretentioner seat is not rightly working. So, I would like to know how to repair or do maintenance work for Pretentioner seat (sensor?).
Instruction manual of barchetta is warning that Pretentioner is no need to lubricate or do maintenance, and it can last only 10 years, but we need to do something when we don't have new part or saving cost.
Additionally, I would like to ask about the battery connection on and off. When I do all those connector works including yellow airbag connectors on and off, do I have to off the battery?
Thank you for your advise.
Akira
Akira
