Hi!
Yep, it sounds OK!![]()
it's kind of db sub so yes, it goes deep.![]()
I can try to record something someday but I don't have proper cam so result can be pretty bad..![]()
i finished sub for my barchetta. here is link.
Hi!
YouTube - Barchetta Subwoofer
I make "box" using free space behind the woofer. I make sealed "box", put some sponge, rubber. I have clear and strong bass, looks good sounds goodwoofer is blaupunkt 200w rms and amplifier is Panasonic 2x190w rms (i used just 1 channel). This is low cost version.
	some quick idea... i'm thinking to put behind windshield/woofer box a ceramic heater + some adjustable air vents to blow on back window. that window is always misty...
	some guy just told me that those ceramic heaters does not have very strong ventilator and should be enhanced with computer ventilators. and (maybe just on my barch) those side air vents on dash have very poor blow to windows... today i removed plastics box (behind holes in dash) and i think there will also fit some computer ventilator + some switch when needed... i'll post pictures later... I'm still at office... :bang:
Impressive work, I am thinking the same. I have a spare dash to play with. I was thinking of incorporating the radio slot also, which means I will have my system lower in the dash.
The vents I was thinking - could I trunk them somewhere else, say behind the seats? Is there anyway you can see to do this or have you just capped them off?
Keep the pictures coming...
Could you also give me the model number of the Sat Nav system you are using?
Just read your orignal message above.
I was thinking about Sat Nav console. But need to know the dimensions.
aah, I'm mounting 7" touchscreen in to dashboard.. If you need, I can measure all the dimensions you want.![]()
Yes please. Thanks![]()
Fiberglassing done, pics on weekend..![]()
