i just recently had new clutch an gearbox fitted an about 3 days after this was done i slowly started to notice a slight banging or clunking(passenger side,i think) noise when driving,it mainly happens when turning left an when going over speedbumps,ive had a look under the car an the only thing i noticed was 1 exhaust mount as got a tie-rap/rip-tie,i had a good pull on the exhaust an this does move slightly an i can make it bang if pulled hard(against the heat shield half way down the pipe,im 75% sure its the exhaust but has any body had any problem similar?im going to try fix it(well i will fix it)at weekend,any thing else i could check while im there?
