durhamjohn1973 New member Joined Jul 21, 2016 Messages 24 Points 12 Apr 18, 2017 #1 My 1.9 non turbo struggles to start when cold, battery & starting motor seem fine, any ideas ?
J jackwhoo Distinguished member Joined Apr 8, 2017 Messages 6,246 Points 1,428 Apr 18, 2017 #2 Glow plugs, injector leak off pipes, Air filter, fuel filter. Compression.
J jackwhoo Distinguished member Joined Apr 8, 2017 Messages 6,246 Points 1,428 Apr 18, 2017 #3 What year is it? How many miles on clock? Has it been serviced properly?
OP OP durhamjohn1973 New member Joined Jul 21, 2016 Messages 24 Points 12 Apr 18, 2017 #4 05, 60k, service last year & just passed MOT no problem, does have small oil leak from somewhere & chucks out loads of black smoke when it does start
OP OP durhamjohn1973 New member Joined Jul 21, 2016 Messages 24 Points 12 Apr 18, 2017 #5 Also drives with no problems, will sit @ 70 on motorway
J jackwhoo Distinguished member Joined Apr 8, 2017 Messages 6,246 Points 1,428 Apr 18, 2017 #6 Glow plugs, injector leak off pipes, Air filter, fuel filter. Compression. on last service were the air and fuel filters changed? check glow plugs first. do you wait for glow plug light to go out before trying to start? try waiting for glow plug light to go out then switch off and give it another glow cycle .
OP OP durhamjohn1973 New member Joined Jul 21, 2016 Messages 24 Points 12 Apr 18, 2017 #7 I do wait for light to go out, this morning it took 3 times to start so maybe glow plugs , will try later
V varesecrazy Patron member 3 Written 10+ guides Joined Apr 27, 2011 Messages 35,077 Points 7,860 Location Near the M4 Apr 20, 2017 #8 durhamjohn1973 said: I do wait for light to go out, this morning it took 3 times to start so maybe glow plugs , will try later Click to expand... hi, cycle the glow plugs.. several heat cycles .. THEN attempt to crank the engine.. if it helps..it's worth changing plugs..
