- Joined
- Jun 2, 2009
- Messages
- 117
- Points
- 46
Ok I don't know if is my earth the that is causing the problem but I have put a new amp in and it keeps blowing fuses so i haven't actually been able to listen to music atm . Basically before with two amp i had two separate ground points. I decided to move to using a ground distribution block (with no fuses in the ground distribution block) and now it keep blowing fuses majorly.
I have a 4 guage down to two 8 guage wires for both the power and the same set up for the ground wires.
Do I just need to sand down the earth more or something so confused right now
