tidynumber2
Does anyone have/had same problem with dab reception and did they manage to solve the problem?
Many thanks....
			Many thanks....
New aerial base probably. It's a common fault I think. I've had mine replaced and it fixed the issue
Where would i locate this earth clamp and battery has a good voltage. Fm works and nav works, just dab says service unavailable??? Thank you for your replyEarth clamp at the bottom got. A good contact?
Battery good voltage?
The bolt holding the aerial base to the roof under the headlining is the earth plate/clampWhere would i locate this earth clamp and battery has a good voltage. Fm works and nav works, just dab says service unavailable??? Thank you for your reply
Ah right yeah I've tightened that as tight as I can get it.The bolt holding the aerial base to the roof under the headlining is the earth plate/clamp
Should be a straight swapNo two second hand ones but it says it was fully functioning when bought, it's funny that I'm getting the same fault code on all bases so I wouldn't have thought it would be that??? Strange??? Could be the radio itself ??? Saying open circuit?? Proper baffled. You don't have to code or program new bases for the car do you or is it like for like??
Well I don't know then, think it's beat me??Should be a straight swap
