Technical Aux blaupunkt
palasio
Hallo I have gp 06 giugaro and I want to install
aux cable.
Any advice ?
You can find the cable required on eBay, type in fiat grande punto aux cable. It has a yellow spade connector which will slot into the back of the head unit. Would recommend reading the article avocet linked. Good luck!
aux cable.
Any advice ?
I'm no expert on this so the following may be wrong ... but looking at the two pictures you have posted I think you may have trouble adding an Aux input.
Compare the back of your radio to the picture of the one in the guide and you are missing the 3 pins next to the Booster pin labelled A.AF-R, A.AF and A.AF-L (Right, Ground & Left audio) where you would expect to connect the Aux cable. What you do have are 3 pins labelled AF.R, AF and AF.L in the opposite corner of that socket. I'm not 100% sure what these are for (they are unused on my radio) but I believe they are connected if you have Bluetooth and USB functionality installed (I don't). Anyway, down in the comments someone with the exact same radio as yours has tried connecting to those pins (Lunatico - comment 73) but was unable to get it to work. He went on to post an alternative solution in this thread.
Some other posts from people with your type of radio also having problems that may be worth a look:
https://www.fiatforum.com/grande-punto/442444-aux-input-buttons.html
https://www.fiatforum.com/lets-talk-fiat/330703-grande-punto-aux.html
https://www.fiatforum.com/i-c-e/151635-aux.html
Despite the above I don't think you've anything to lose by trying to make a connection to the pins - maybe the people above got their wires mixed up or something?!
Best of luck!
Thank you guys...
I will try but I think there isn't aux at this type
so I try something else ...
