General Autotrail marker light fuses
Matthemedic
Hi everyone. I have purchased a year 2000 autotrail cheyenne motorhome and have no front marker lights or the rear side ones (high level red and white ones) I've got v- at bulbs but no v+. I've search for the alusive fuse box behind the drivers or passengers seat but have not got one. Can anyone shed some light on the fuses location. Maybe even a picture as I've hunted high and low..many thanks
Depends on the make of the base vehicle. Many fuse boxes are behind or below the glove box.
Doesn't it tell you in the handbook?
The main fuse box is in glove box but apparently there is I another just for the marker lights and rear supplies. I rang autotrail who said it should be behind driver/passengers seats in floor but can be else where?
hi most motorhomers on here belong to a forum as well like motorhome fun & for i think £12.50 to join you should get someone with the same van as you where you will get information on the habitation side of things i have had 3 autotrails & usually their is 1 fuse box under the bonnet 1 behind the drivers 1 in the dashboard somewhere depending on what model & 1 in the cupboards but that one is for in the living quarters hope this helps
the only fuses that can be for the markers can be found in glove box the markers are run off the side lights rh front s/lfuse 6 7.5 amp Lhfront fuse 5.RH tail light fuse 5 LH tail is fuse 6 all7.5 amp.i would check the side lights as all markers on my AUTOTRAIL run off these.
