Technical  Armrest/gear knob vibrations
P45
HI there.
I'm new here , the name is Danny
I own a 2011 120 T-jet Bravo Dual Logic.
When the car is in neutral/idle and not moving , there are noticeable
and quite annoying vibrations on the armrest ,gear knob , and a bit on the steering.
It doesn't occur when driving around.
In the past I've had the entire dashboard vibrating , So I changed the main lower engine mount , (which as my mechanic said was the problematic one , and most prone to ware) And it solved the problem.
SO by going in the same line of thought I replaced the gear mount as well , but the vibrations are still here.
Is it the second - top engine mount or is it there something else that causes it?
Best Regards :)
Probably worth a check. For a couple of weeks before my exhaust snapped, there was a loudish vibration when sat at lights but gone when I set off. The mechanics said its because part of the exhaust is loose or partially broken and the mounts can't take the vibration away properly. I could be wrong on your car. But have a check on the condition and security of yours. Just to rule it out
It's not just a FIAT. It's a way of life.
  • Thanks
Reactions: P45
it's sound alarming a bit I must be honest :)
My car is relatively low mileage , it's done only 37,000 miles.
So i'm not sure if it really is the reason but it's worth a look.
And if that isn't the case (and I hope it isn't :) ) what else could it be?
