paganeli panda
http://www.gazzella.cc/cart.php?target=product&action=view&product_id=16994&category_id=873
following Kiry's post I found this set, is it worth getting it?
FYI only the front will be height adjustable.
The rears can be adjusted in height, they can on the Punto's anyway so I don't see why the Barchetta would be any different. The bottom cup is simply threaded, the spring seats as normal and you screw the washers up/down to compress/decompress the spring.
Spend the extra money and buy silverlines, they're stainless and don't corrode.
Highsports/konigsports corrode quickly (I've had all of them, I should know).
I get you, so you get a replacement lower spring mount that can be raised and lowered off the swingarm, thus changing the cars ride height. Cool I want that kit even more now hehehe
