General Annoying Speedo Problem...
Frank S
Hi, anyone here come across this problem; my SeiSporting speedo only starts working at the 40mph mark, any slower than this and its back to zero... :mad:
All the fuses have been tested.
Thanks!
Frank
...Just checked the box. Seems to be rectangular and black. No circle. :confused:
Frank
Possibly not a cable one, you are at the cutoff in terms of the changeover so you might have an electrical driven one, but would go with the concensus in that the cable has probably had it and needs replacing.
As said check for the two different style of boxes/connectors to see which version you have.
There is also a guide on here on how to remove the speedo pod should you need to
