Technical  AMT temporary failure. Electrical issue?
ashesu
Arnhem
Hello.
I have a 2009 1.2 Fire Panda with an automated manual gearbox. Today while driving, during a gear hange it got stuck in neutral. No warnings in the dash. Turning off and on the engine, moving the shifter in any way did not help. I once heard an unusual noise coming from the gearbox - the pump/motor that controls the transmission. A few minutes later when I started the car again everything started working normally.
Also, since few days ago steering wheel warning dash light with text "have power steering checked" started coming up sometimes although everything seemed to work normally.
I'm thinking these might be related to some electrical issue. Though the battery is relatively new (1.5 years old) and was changed with the dynamo recently according to the man who sold it.
For a month everything was fine, I drove mostly with city mode on too.
Any ideas what this could be in particular?
I would check the battery voltage with multimeter and look for issues with OBD2 but I don't have these at the moment.
I appreciate any help.
Model
Dynamic 1.2
2009
Mileage
110000
You can force it to drop that low if you put absolutely everything on
At idle should be 14.1 nothing on
With the rear heated window , head lights and blowers on full it should be in the mid to high 13s
At idle back to 14.1 If you rev it a bit
Right, thanks.
So that one Dualogic failure remains a mystery. I'll drive the car for now.
Aaand it happened again. Went into neutral in the middle of the road.
No noise from the gearbox at first when moving the shifter. After a few minutes some quiet unusual noise as if it's struggling to change gear. After a few more minutes and restarting the car it's all back to normal. All same as the first time.
I don't think the whole actuator is busted since it all goes back to normal.
Could it be pump relay?
The accumulator (black bulb)?
The pump motor?
Will Multiecuscan give me a clue here?
Yes there some thing that can be done with multiecuscan I guess the first is scan for codes on the dialogics control unit
This might tell us a direction to go next
Some common ones below
P1760 – Brake Switch
P0571 – Service Brake Switch (from CAN)
P1741 – Clutch Position Sensor
P1742 – Multi-position Sensor (range sensor)
P1743 – Clutch Plate Sensor
P1769 – Pilot Pump Relay Switch Is Stuck (Pilot Relay)
P1810 – Incorrect Clutch Work at gear shifting
Р1773 – Hydraulic Circuit Pressure
P1744 – Hydraulic Circuit Pressure Sensor
С0060 – ECU Failure (Microchip)
P1818 – Gear Shifting Control
You can look at the pressure and it should fall gradually with each gear shift
Engine on
Change between 1st, R and Neutral the pressure should not go below 36 and should immediately pressurize back to 46/48 bar
Engine off, the pressure shouldn't drop more than 3 bars.
You can look at the clutch wear index
There's enough for now to be going on with
Engine on
1 stored error: P1818
Clutch degradation index: 3951
The hydraulic pressure graph looks like this when changing the gears around ~5 times in MAR. Seems too spiky.
Forgot to check engine off pressure drop, will do when I can.
By the way, the yellow OBD2 cable wouldn't connect. Various errors and even when there were no errors and test got completed successfully it still wouldn't connect.
If the bluetooth adapter alone can do this, what is the point of the yellow cable then?
The Multiecuscan scan and graph are exactly what we needed. You’ve now got a real Dualogic code P1818 (Gear Shifting Control) and the hydraulic pressure trace. The way the pressure goes spiky instead of stable tells me this is likely a control/signal issue, not a broken actuator.
Common causes at this stage are:
wiring/connector issues to the gearbox or pump/pressure sensor
poor ground to the AMT ECU
intermittent pump relay or sensor signal.
Check all harness connectors and earths at the gearbox and AMT ECU, confirm good power/ground.
Pressure regulation faults like this rarely show on cheap readers, Multiecuscan is doing exactly what it should. Once connectors and grounds are confirmed good, we can narrow it further based on any additional codes.
Should be fine unless someone has previously reset it, normally good if under 6000
P1818 is the worse code to have, it doesn't help much, it basically saying something gone wrong, help, it has many causes,.from simple thing like oil change, low oil, to serious internal problems and everything in-between
The graph is pretty interesting, it's dropping twice as much on each gear shift which is concerning, the pump kicking in at the right place and stopping in the right place, I am favouring the accumulator, part of its job is to smooth out the presures as well as storing pressure, the only way I know to test them is to depressurise the system and weigh them, should be around 650g give or take 50g or so, the have a lifespan typically of 60-80K miles
am not an expert on dualogic. I don't know how much pressure drop is worn but acceptable,
One of the symptom of a failing accumulator is faults starting to creep in
Do the pressure drop test with the engine off,
Swapped relays. No apparent change.
Did gearbox self calibration with MES. After a minute of noises from the gearbox it got completed with a message "N/R selection error".
Will thoroughly check gearbox connectors later.
Anyone here by chance know a good specialist on these gearboxes in the Netherlands?
If I'm seeing it correctly, it drops just around 1 bar.
Which is good no internal leaks
This should work on you car,.but I have no idea what the values should be
No idea about the Netherlands,.here in the UK there's not many people that will touch the dialogic
@A3jeroen is from your country and is a regular contributer to the forum,.maybe they know someone
Sorry I can't be of more use
Dualogic is not my area of expertise
The accumulator looks favourite to me, they last between 60-80K miles normally but there's no hard and fast rule
It's a £70 part I would want to be more sure than this before ordering one
If it was my car I would depressurise the system, remove the accumulator and weigh it , not that hard to do
There's a guide on here on changing if you go that route
Thanks for all the help so far. Will look into that this weekend.
G'day
So, I brought the car to the dealer, he sent it to a mechanic. They couldn't find any fault and I was told the issue was most likely...my 100€ Android multimedia unit from AliExpress. At first it sounded to me like nonsense. I fully disconnected it, ran MES final gearbox calibration and...this time it completed with no errors. Since then I've been driving the car for like 3 months, no issues at all.
I'm going to use fuse tap on driver's side for power to the multimedia unit and cut a few wires that apparently talk to ECU. This way there should be no electrical link between it and the gearbox.
Aaaand it happened again. Multimedia unit was completely disconnected, I haven't done the planned fuse tap thing yet. So it's not the culprit.
This time the car haven't recovered after even 10+ minutes. Restarts, battery disconnection didn't help. What seemingly worked was, with just ignition on, pushing the car with my foot out and then quickly engaging D gear while it was rolling a bit, only that made it go out of N and start changing gears properly afterwards. Also this time the pump was silent after waiting and opening the driver's door during the failure.
At this point I'll press the dealer with this issue, I've done all I could to find out and I don't know what it is.
Hello.
강남은 현대적인 분위기와 다양한 힐링 공간으로 잘 알려진 지역입니다. 바쁜 일상 속에서 피로를 풀기 위해 마사지와 스파를 찾는 사람들이 많습니다. 도심 한가운데에서 강남출장마사지라는 표현은 온라인 검색에서 가끔 언급되기도 하지만, 실제로는 검증된 합법적인 힐링 서비스 이용이 중요합니다. 많은 방문객들은 전문적인 테라피와 스파 시설을 통해 편안한 휴식을 즐깁니다. 강남은 건강과 웰빙을 위한 다양한 선택지가 풍부한 곳입니다. 전반적으로 안전하고 신뢰할 수 있는 힐링 문화가 자리 잡고 있습니다.
Almost certainly an electrical supply issue. The automated gearbox gets stuck in neutral when voltage drops briefly and the power steering warning appearing at the same time confirms it since two systems failing together means a shared cause.
When you get a multimeter check battery voltage at rest which should be 12.6V or above and with engine running which should be 13.8 to 14.4V. Also check ground strap connections at the battery negative and chassis for corrosion. Older Fiats are notorious for bad grounds causing exactly this kind of intermittent multi-system weirdness.
Sounds to me like
Hydraulic pump faulty
Pump relay faulty
Any error codes ?
Pitty you didn't put the diagnostics on while it was failing
A look at the pressures might have given you an answer
Or try software gear shifting, or actuating the pump
You could try swapping two relays over and see if the symptoms change. Assuming this fuse box is the same as yours
I suspect it needs to go to someone knows what they are doing, the pressures don't look right
That was done. Ground strap was changed, connections are ok, voltage is ok.
Is the Dualogic fluid level low and do you have weepage near the clutch actuator?
When this first started happening I did check it. The level was ok. It was said to be changed recently too.
Sounds to me like
Pump relay faulty
Any error codes ?
I did swap relays months ago. Error code is always the same one - P1818.
There are no symptoms to check. It just gets stuck in N once every few weeks or months. When it's working, it's working fine and I've checked pretty much every parameter in MES and it all appears ok.
