Amp Setup
Amp Setup
A
Anonymous
Guys, just fitted my new JBL6000 amp, i;ve amped my sub, sounds sweet now, ive tried to amp my speakers, but for some reason there not workin, what the hell am i doing wrong.
Re: Re: Amp Setup
yeah the power light comes on, and also my subs working, just dont seem to get any sound from the speakers..
Re: Re: Re: Amp Setup
How many RCA cables have you got going onto your inputs? How many speakers have u set up from the amp?
Re: Re: Re: Re: Amp Setup
ive only currently got my sub runnin from the amp, just wanted to do the back speakers, only got the one RCA cable.
do you need to have racs to all the channels you want to use at the mo i have a 4 channel brigded down to 2channels with 1set of rcas ive got another 4channel for the install going in this weekend im usiing all 4 channels do i need to have rcas to all the channels. Danny
Re: Re: Re: Re: Re: Amp Setup
There's your prob then!
Your RCA cables are in your 'sub in' on the amp. To power more speakers from the amp you need an input for a signal. If you only have 1 RCA out on your head unit you can get a splitter to use more inputs. There are 3 lots of inlputs on the GTO6000 - sub, front and rear.
They need inputs for a signal to the speakers
Yes.
You can buy splitters though if you do not have enough outputs on your head unit
Re: Re: Re: Re: Re: Re: Amp Setup
i have the amp at the mo running from the sub out and i still have 2 rcas outs so i need to run these 2 to the new amp cheers wimmy mate.
so i need to buy a splitter and another RCA cable, just to run the back speakers, how about if i brought another set of speakers for the parcel shelf, what would i have to do then.,
Anonymous, now your confusing me, lol
Basically u need an input in your amp for every output.
If you plan to run subs, rear and front speakers you need 3 sets of RCA's going into your amp.
The inputs correspond to the outputs
You MUST feed a signal to both of the channels which you have bridged. You need to buy some splitters.
Re: Re: Re: Re: Re: Re: Re: Amp Setup
on the amp i have brigded i have 1 set of rcas going to channel 1and4 or 2and3 something like that do i need another set of rcas for this amp aswell
Re: Re: Re: Re: Re: Re: Re: Re: Amp Setup
Danny, did you read the instructions?
You should have
1 RCA split into Front L&R and the speaker connected to Front L- and Front R+.
1 RCA split into Rear L&R and the speaker connected to Rear L- and Rear R+.
Re: Re: Re: Re: Re: Re: Re: Re: Re: Amp Setup
right ok so i need another set of rcas it sounds fine seriously loud and bassy but il ad another one to it.ive got some splitters at home as il seem to neeed them when connecting up my next amp.
N
5
492
M
A
2
234
Insomnia
I
S
4
346
M
K
4
332
K
